View the IPv6 Active RP
Perform this procedure to view information about the IPv6 active RP for all the running multicast groups on the switch.
- Select IPv6 PIM.
- Select the Active RP tab.
Active RP Field Descriptions
Use the data in the following table to use the Active RP tab.
Name |
Description |
GroupAddress |
Shows the IPv6 address of the multicast group. |
Address |
Shows the IPv6 address of the RP router. This address can be one of the local PIM-SM enabled interfaces or any reachable global IPv6 address configured using the static-rp CLI command. Note:
IPv6 link local address is always used as the PIM interface address. |
Priority |
Shows the priority of the RP. |
